How to add text at cursor-position
i have two string-controls with text inside.
I have also a button. Now i want to click with the mouse in stringcontrol_2 at a special position, then click the button and then the text from stringcontrol_1 should be inserted at the position in string_2 where i was with the cursor before.
Is this possible?
Thx for any ideas
(3,657 Views)
Accepted by OnlyOne
Hi OnlyOne,
you can use the keydown event of the string control. Inside of this event you can read the property "Text.selection". If you don't select a text range, then start and end are equal, but they show where the cursor was placed. You can store these values in a shift register to use them in the button "value change" event.
Mike
(3,645 Views)
Hi MikeS81,
thanks for the fast help. I used the mouse-down-event because keydown is for keyboard.
But now it works great.
(3,612 Views)
