Hi mike
You could display your signal in a XY-Graph. There you have the possibility to show your peaks also, because if you're using Peak Detect.vi you have the location and the amplitude of each peak. This you can display also in a XY-Praph.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
