How to add labview frontpanel into visual studio
I'd like to add the whole frontpanel of my simple labview programm into the frontpanel of my visual studio programm.
I allready created the DLL and added it to my visual studio programm, and now, I'd like to view the vi frontpanel in my visual studio form.
Is there any possibility to do something like that without using the measurment studio .NET?
Thanx a lot!
(2,998 Views)
Thanx a lot!
Maybe. You could try to get the Windows handle to the LabVIEW front panel using Windows API functions, and also using Windows API functions to parent that window into your application window. It could work but might be quite a tricky and not very stable solution since your Visual Studio application window message loop really is in another context than the LabVIEW runtime engine window, the VI uses.
Message Edited by rolfk on 03-12-2010 01:42 PM
Rolf Kalbermatter  My Blog
(2,972 Views)
Hello labview_vr,
the easy solution: you can configure the VIs in your DLL so that their front panels will be opened when the corresponding function is called. Additionally, the front panel can be configured so that it will be closed again when the VI code has finished execution. Minor drawback: the VI front panel will float atop of your VS application...
Sebastian
(2,965 Views)
