How to add data to an access database with connectivity toolkit?
I'm trying to add data to an access database using the connectivity toolkit of Labview.
At this moment, I have one row in my database: [Lindex lindex 0 0 0] with the first two elements of string type and the last three elements of double type. I want to add a new row [Hello hello 0 0 0] in my database using the "Insert Data" block, but it doesn't work properly.
Can anyone help me out?
Thanks!
(2,904 Views)
You've closed the connection to the database before your Write operation.  Don't do that!
Jim
(2,885 Views)
I did an edit to my vi, but it still gives an error (see picture). I also took a printscreen of my access database.
Can u also tell me how to get the coercion dot away?
Thanks!
(2,858 Views)
Your Columns-array to the Insert to DB is empty.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,848 Views)
