‎05-26-2008 04:22 AM
‎05-26-2008 04:53 AM
‎05-26-2008 05:37 AM
You can add several *.bat files into your distribution. Each one will call your application with different arguments. So, you can put shortcuts to *bat files instead of executable. I haven't tried this, but it should work.
Andrey.
‎06-03-2009 09:44 AM
Hello Forum,
Does anyone have any better data for this? I would also like to create an installer using Labview Project Explorer tool (Build Specification->Installer), and I have a need to create some shortcuts to some EXE's (VS.NET built, not LV) which need to have some arguments passed. I just verified that LV8.6 still does not seem to offer the option of passing arguments when creating shortcuts. Is this correct? Creating stub EXE's or batch files isn't a good option for my project, so I'd like to have someone confirm if LV installer tool can't create shortcuts w/ arguments before I fire up InstallShield.
Regards!
