How to add command line arguments to shortcuts in the LV8.5.1 installer
I want to create multiple shortcuts to my LV program, each with different command line arguments.
I can do this manually.
I want the installer to generate these shortcuts.
I can add different shortcuts in de installer build specification, but I cannot add commandline arguments in the shortcuts.
Does anyone know how to do this?
Rindert
(3,298 Views)
You could have your application at first run do this for you. Create an ini-file parameter that gets deleted on first run.
André (CLA, CLED)
(3,293 Views)
You can add several *.bat files into your distribution. Each one will call your application with different arguments. So, you can put shortcuts to *bat files instead of executable. I haven't tried this, but it should work.
Andrey.
(3,282 Views)
Hello Forum,
Does anyone have any better data for this?  I would also like to create an installer using Labview Project Explorer tool (Build Specification->Installer), and I have a need to create some shortcuts to some EXE's (VS.NET built, not LV) which need to have some arguments passed.  I just verified that LV8.6 still does not seem to offer the option of passing arguments when creating shortcuts.  Is this correct?   Creating stub EXE's or batch files isn't a good option for my project, so I'd like to have someone confirm if LV installer tool can't create shortcuts w/ arguments before I fire up InstallShield.
Regards!
(3,115 Views)
