How to add a missing character value
I am reading from text files and have blank cells in data sets which I would like to keep blank rather then labview intuitively reading them as zeros. Is there a way to add a character for labview to read over that particular cell?
(2,817 Views)
You need to provide some more info on exactly how you are reading the text file. Are you converting the text to a number? What's the final destination of the text file data - array of numerics? Post an example of what you're doing if you can.
Tim
(2,817 Views)
i have the same problem with missing values known as zeros. my txt file is read by sub-vi "read characters from file" then with "spreadsheet string to array" i convert it in numerical array. then missing values are coded like zeros.
How doing ?
Thanx
Matt
(2,817 Views)
There's a couple things you might try. Before you do the Spreadsheet String to Array, if your spreadsheet string is something like 1.1,,2.3, then you could do a search and replace of ,, and stick in some number you wouldn't normally see or NaN (Not a Number). You could also first create a string array with Spreadsheet String to Array and search the array for an empty string and replace those values before doing the conversion to a numeric array.
(2,817 Views)
