How to add 2D array at the end of another 2D array
how can i a add two 2D arrays together so that array two is not after it but at the end as marked in screenshot?
Thx for help
best regards
TM
Message 1 of 14
(3,955 Views)
Like this:
That extra function I added is: Functions -> Programming -> Array -> Matrix -> Matrix Size
Message 2 of 14
(3,950 Views)
Don't over-complicate things! The correct function is "built array". Make sure to set it to "concatenate" mode by right-clicking. No need to get dimensions, etc.
("Insert into array" is a much more complicated function, requires more inputs, and is most useful if you want to insert somewhere in the middle. It is not needed here!)
Message 3 of 14
(3,925 Views)
Actually, the OP wanted the 2nd array to the right of the first array and not below.
I, myself, would have used Build Array, but with Transpose Array a few times to locate the 2nd array.
One thing Altenbach does basically say is that Build Array is usually the right answer over Insert Into Array.  I'd say 90% of the time where someone has been using Insert Into Array, they probably only needed Build Array.  I think I can count on one hand the number of times in my LabVIEW programming I've needed "Insert Into Array".
Message 4 of 14
(3,917 Views)
Sorry, for misreading. Sometimes it is difficult to know what the OP wants vs what he gets. 😉
(The title was somewhat misleading, stating "...at the end of another 2D array". The way 2D arrays are arranged in memory, my solution was closer to the description. To append rows, the data needs to be interlaced in memory, which is more effort!)
Assuming that the array have the same number of rows, there is no need to transpose. Just add a FOR loop.
Message 5 of 14
(3,908 Views)
Thx for all help. meanwhile i solved it too
Message 6 of 14
(3,894 Views)
Technically, transpose is probably quicker.  It's probably a no-op, I would think.
Bill
CLD
(Mid-Level minion.)
Message 7 of 14
(3,880 Views)
Of course the general case would need better specifications. Do the array sizes match in some ways (Do the number of rows match? Columns? Both? etc. How should they be aligned/padded if the sizes don't match? etc.)
If this is just a one-shot deal, you are probably fine, but if you for example want to keep appending new arrays over and over, you should probably re-think your data structures and make sure that the new data is kept mostly consecutive in memory by keeping it transposed. Just think about it! 😉
Message 8 of 14
(3,876 Views)
Probably not, because the two arrays need to be interlaced in memory, requiring a new allocation.
(Technically, the compiler might actually create the exact same binary code for both versions. ;))
Message 9 of 14
(3,872 Views)
I was thinking that the memory would just be "reconsidered" as is the case with a reversed string, but you're saying that manipulating a multi-dimensional array would be more complicated?  In other words, LV would actually have to re-create the data, not "reconsider" it?
Bill
CLD
(Mid-Level minion.)
Message 10 of 14
(3,869 Views)
