How to activate low pass filter of 6115 with daqmx?
I am not able to find the property node to activate the low pass filter of the 6115. Could anyone give me a hint?
Thanks a lot.
Michael
(5,144 Views)
Accepted by MichaGue_01
Hello MichaGue_01 and welcome to NI Forum,
This might help:
Which SMIO (S Series) Devices have Antialias Filters?
http://digital.ni.com/public.nsf/allkb/2326CE69C921A90286256F0800638E10?OpenDocument
(5,127 Views)
thanks a lot. Can a activate each channel of the 6115 seperately or is the property for all channels?
Michael
(5,064 Views)
I have the same question but I want to know how can I activate lowpass filter on an analog signal via NI-Daqmx python API? I have found the following APIs but it seems that still I am missing some more i.e. how to select a channel/port for the sigal? what should be the cutoff freq and ect. Kindly explain with a coding example.
ai_lowpass_enable
bool – Specifies whether to enable the lowpass filter of the channel.
ai_dig_fltr_lowpass_cutoff_freq
float – Specifies the lowpass cutoff frequency of the digital filter.
(3,358 Views)
I don't know the python text-based API into DAQmx, but am just wrapping up a little project that uses the 6115.
There are only 2 supported values for the cutoff freq, either 50 kHz or 500 kHz.  You'll need to identify a DAQmx task when you call the function to set this, and the setting will apply to all channels in the task.  (Same is true for the "Enable" setting.)
Because the 6115 is a simultaneous sampling device with multiple A/D converters, it's conceivable there's a way to set these differently on a channel by channel basis.  I can't say for sure because I had no need to explore that possibility.
-Kevin P
(3,353 Views)
