How to Reset Factor value at time of Reset the system.
I am facing one problem regarding to Reset the factor value in attached vi.
In that I have used 4 button Start, OK, save, stop.
In that initially vi ask to set the factor value , then press start and reading will vary and then press OK then reading is add to the array table.
For second reading again press start and measure the reading then OK to add to array.
After some reading when I press save button its save all reading to txt file and reset the all the vi but its not able to reset the Factor value.
How can I reset the factor value also after pressing save button.
I know here its out side of whileloop so its not possible to reset in this case I tried to set it into the while loop but I didn't get success.
Please guide me.
Thank you very much.
(2,777 Views)
This is not a TestStand question! Please post it in the LabVIEW board.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,761 Views)
Accepted by topic author AnkitRamani
ohhh, sorry for that...it was out of my mind..
thank you .
(2,754 Views)
