How to Read magnetic sensor data via I2C
Hello All,
I hope you are doing fine.
In my previous post, I asked about how to receive data from a magnetic sensor via I2C in LabVIEW, which was resolved thanks to the member of this discussion group.
As am currently new to LabView software, I will be requiring some of the support from this group to help me how can I connect two sensors to Myrio.
I was able to connect these sensors (TLV-493D) via I2C in Arduino and also received data but somehow having a problem in LabView.
According to the sensor user, manual page 22 manual attached. When 1 sensor is on with the master board (Arduino/Myrio) its address becomes 0x5E and when other is turned on after 200 micro sec its address automatically changes to 0X1F. (https://www.infineon.com/dgdl/Infineon-TLV493D-A1B6_3DMagnetic-UM-v01_03-EN.pdf?fileId=5546d46261d5e...).
I have also attached the snapshot of my VI.
Moid Khan
(2,315 Views)
Hello MoidKhan,
What's exactly your question?
(2,271 Views)
Hello KRojas,
 My question is when I connect single sensor, MyRio picks up that sensor's bit address i.e. 0X5E, But when I connect the second sensor it doesn't pick up its Bit address value i.e. 0X1F.
M.Moid
(2,267 Views)
