How to Generate ramp waveform in LabVIEW
Dear Friends,
I want to generate an analog voltage waveform with initially 0V output for 5 sec followed by a ramp waveform with 1V/sec to reach 5V in sec. After reaching the 5V the waveform should stay at 5V for another 10sec. How can i Generate this LabVIEW please suggest me. I have attached the figure for detail
Thank You
Message 1 of 11
(7,580 Views)
Hi prasad,
So there are 3 parts in your waveform:
  1. a ramp from 0 to 0 with a duration of 5s
  2. a ramp from 0 to 5 with a duration of 5s
  3. a ramp from 5 to 5 with a duration of 10s
To create this you basically need three functions: RampPattern, BuildArray and BuildWaveform.
See how far you get. In case of problems attach your VI with your questions…
Message 2 of 11
(7,551 Views)
Dear Sir,
I have Created this Pattern in Control and simulation loop. But I want to create the same in LabVIEW panel. I have attached the VI. Please help me to create the waveform in LabVIEW.
Message 3 of 11
(7,544 Views)
Hi prasad,
as I wrote before:
You basically need 3 functions: RampPattern, BuildArray and BuildWaveform.
So how far you get and post your VI for any other questions!
It's your homework - and you get the credit for learning LabVIEW…
Message 4 of 11
(7,541 Views)
Dear Sir,
I created The VI as you told. But Do i Need To add these waveforms or any other Thing that i can do ?
Message 5 of 11
(7,538 Views)
Accepted by prasad145
Hi prasad,
why do you create 3 waveforms when you only need one?
All those ramp parameters were different to your previous requirement…
Message 6 of 11
(7,531 Views)
Dear Sir,
Thank You for the Result, I have a problem in building an array its not showing adding arrays its adding elements. How can i convert that element into array format. Please suggest. I attached the VI.
Message 7 of 11
(7,513 Views)
Thank You Sir,
I got the result. I got how to create that element to array type. Thank You for the Support.
Message 8 of 11
(7,506 Views)
Dear Sir,
Here I have one more problem to generate analog waveform. Because there is no sample information. How can I add sample information to generate the voltage? I have attached the Application VI using the above ramp waveform. Please help me to generate analog voltage.
Message 9 of 11
(7,476 Views)
Hi prasad,
get rid of that ExpressVI (aka DAQAssistent) and create a proper DAQmx task with useful settings!
Right now the task is created with "1 sample on demand" timing - and you wonder about not being able to output a waveform?
LabVIEW comes with a huge example library. There are a lot of examples about DAQmx function. There are examples showing how to output waveforms. You can even use the timing information from your waveform for your DAQmx task…
Message 10 of 11
(7,470 Views)
