05-10-2012 02:20 AM
Dear all,
I am controlling a motor which is pressing to load cell. I am controlling the motor position with a numeric controller in the front panel, the question is when i accidently enter a large value(undesired motor's new motor position), than it could damage the load cell.
In this case : Can we arrange a numeric control in the front panel so that it can accept numbers only between "0" and "10".
Also : Is it also possible to arrange this from block diagram with wiring reference element as maksimum limit to the numeric control ?
Kind Regards,
Best Wishes.
05-10-2012 03:23 AM
Dont know of any specifc way to to this, could use a slide bar instead, and make to top limit the highest number you wish to go to. Or you could program in a safe gaurd using a case statement. "If the number entered is grater than a value allowed", write the highest value allowed,( you could add a boolean light to indicate that this has happend also) else, write the number entered.
Hope this helps.
05-10-2012 03:23 AM - edited 05-10-2012 03:24 AM
Right click on your numerical control, go to properties, click the 'Data Entry' tab. Un-tick 'Use Default Limits'.
You can now set Minimum, maximum, Increment etc.
This can be done with a property node too if you want to change the values programatically.
05-10-2012 05:05 AM
Thanx guys, both ways are helpful. I will try it on weekend.
Kind Regards.
08-25-2012 09:25 PM
Phil_
Following setting the "Maximum Limit" for the desired value, is it possible to programatically save this "Maximum Limit" as the default "Maximum Limit" for that numerical control? I mean, even closing the VI and opening again the "Maximum Limit" will be the one that was set programatically before.
Thanks.
Dan07.
08-25-2012 09:55 PM
As long as you've saved the VI after setting the new limits either manually or programatically, the new limits will be there when you reopen the VI.
