How to Create an Array from Formula Node Output Values
Yes, it does sound like you'll want a loop.
You'll want to store the value of X in a shift register, which passes the values from one iteration of a loop to the next.
This version will perform all the calculations with the original X values, [1,2,3,4,5,6], and then perform all the calculations again with the new X values. All other input values to the second iteration will be unchanged.
I think this is what you described, but I'm getting a bad feeling that I'm drifting farther and farther way from understanding what we're actually trying to do.
This will run twice. You can change the N input if you want it to run more, or you can change the For Loop to a While Loop if you want it to run until some logical condition is met.
Message 31 of 33
(1,178 Views)
"This version will perform all the calculations with the original X values, [1,2,3,4,5,6], and then perform all the calculations again with the new X values. All other input values to the second iteration will be unchanged."
The sentence above is my goal so we understood each other. Can you upload the VI so I can check?
Message 32 of 33
(1,176 Views)
I hope this helps.
(Sorry, upload the wrong file first time.)
Message 33 of 33
(1,174 Views)
