How to Create SQL "Databases" from LV?
Is there a way to create SQL Databases (not just tables) from inside LabVIEW???  This sould be fairly easy...
(4,974 Views)
All I know is what is in the SQL Server help file. There is the SQL command "CREATE DATABASE". An example is:
USE master
GO
CREATE DATABASE Sales
ON
( NAME = Sales_dat,
   FILENAME = 'c:\program files\microsoft sql server\mssql\data\saledat.mdf',
   SIZE = 10,
   MAXSIZE = 50,
   FILEGROWTH = 5 )
LOG ON
( NAME = 'Sales_log',
   FILENAME = 'c:\program files\microsoft sql server\mssql\data\salelog.ldf',
   SIZE = 5MB,
   MAXSIZE = 25MB,
   FILEGROWTH = 5MB )
GO
You have to have the correct permissions in order to do this and the server itself has to exist. I'm assuming that you already have the Database Connectivity Toolkit, LabSQL (http://www.jeffreytravis.com/lost/labsql.html), or are using your own ADO routines.
(4,956 Views)
I am using the LV "Database Connectivity Toolkit" that ships with the Prof. Dev. Suite.  I am going to download and look at LabSQL 1.1 from your website today.  I am assuming it offeres more speciallized SQL functionality?  Does it allow you to execute scripts like the one above from inside the LV block diagram?
(4,943 Views)
They both do. At the heart of the Database Connectivity Toolkit, it issues SQL commands. I don't have the toolkit but I'm pretty sure that there is a function in there to issue a SQL command directly. Most of the toolkit is functions that hide some of the complexity of SQL and allow you to build an application faster without knowing the SQL language. With LabSQL, the only interface is SQL through ADO.
(4,939 Views)
Here's an example of how to do any SQL query using the Database Connectivity Toolkit VIs:
(4,912 Views)
Your figure looks like its executing a select query or something similar, i.e. it returns a recordset.
What would it look like executing a "create database" script?  Would it be the same, just without the "Fetch Data"?
Thanks.  Soon I need to stop asking questions and just go try this stuff 🙂
(4,893 Views)
Exactly, the code would be the same without the Fetch subVI.
(4,869 Views)
