How to Check date within limit
Hello 2 all,
Plz Help me i am new 2 Labview
i am using labview 8.2.1
i want 2 check the given date within the From and To date for Report generation.
plz help me if any one knows, i need it urgently.
Message 1 of 12
(5,732 Views)
Use inrange and coerse from comparison pallette.  This will be polymorphic to the time date type.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 12
(5,728 Views)
sir i want From And To date are variable
Message 3 of 12
(5,722 Views)
Yes, how does that change the answer that Paul gave you?  Use wires from controls or formulas into the Max and Min inputs of the In Range and Coerce function instead of constants!
Message 4 of 12
(5,711 Views)
Accepted by Mukesh Krish
sir plz find the attachment
inrange function only checking day its not consider month and year plz give me your suggestion and solution plzzzzzzz
Message 5 of 12
(5,705 Views)
Message 6 of 12
(5,699 Views)
I imagine that when you pass a string into In Range and Coerce it does an alphabetical check.  It doesn't know you formatted the string as a date.  It just sees a string.  Use time stamps.  An example is attached.  It's LV 8.5
Tim Elsey
Certified LabVIEW Architect
Message 7 of 12
(5,686 Views)
How come you marked your reply as solved when it is not a solution, but another question?
The problem is that you don't have dates.  You have strings.  So if you convert those strings to dates, then you will be able to use th In Range and Coerce function.
See attached.
Message 8 of 12
(5,683 Views)
You dont want to use string you should convert to date time.  This can be done using the scan from string and <T> time format.  Without seeing your time date strings I cant give you the exact conversion.  Once in a time date format (NOT STRING) then use inRange
Paul Falkenstein
Message 9 of 12
(5,681 Views)
Message 10 of 12
(5,660 Views)
