How to Change List Box's Text Color...?
Hello, I have attached VI that I can drag text from Master List to Current List; I'm loosing Text's color in Current List (especially "Start Loop & End Loop" content) after dragging. I've tried with Properties like, changing the Active Row's Cell Color; that doesn't help me out. Would any one help me on this...? Appreciate your help. Thanks
(3,146 Views)
Sorry Folks...I've missed to attach VI. Here you go...
(3,139 Views)
When you perform a drag and drop neither the Active Row nor the Edit Row is updated. Your code even verifies this from the fact that the Active Row is not changed. The closest you can come is to use an event structure and respond to the Drop event. This will return the coordinates of the drop and then you can use the Point to Row method of the control to get you the row.
(3,104 Views)
