How to Build All for LabVIEW RT Project with multiple FPGA routines
I'm working on a medium/large Project running in a LabVIEW RT Project, where the Target is a RIO with an FPGA.  I have multiple FPGA routines (to test individual pieces, to work with specific RT-Target Stand-alone Tests, to work with other Target routines that work with test Host routines, etc.).  I'm familiar with the ability to "Build All" for LabVIEW and LabVIEW RT that allow you to queue up multiple Build Specs to be run during lunch or overnight, and for LabVIEW VIs that allow you to write a "Build Selected" routines programmatically.
What I'd like to do is to do the same thing for the various FPGA routines in my Project.  Thanks to the availability of the Compile Farm, I can spend 3-5 minutes while everything is uploaded to the cloud, then I'll have my machine back and can let all the compilations take place without interruption.  But I don't see any tools to allow me to do this.
Am I missing something?
(2,270 Views)
Accepted by Bob_Schor
If you have more than one FPGA build specification, you can select more than one, right-click, and select Build.  All of build specifications will kick off.
ALE Consultants
(2,264 Views)
Thanks, Terry!  So simple, and it just didn't occur to me ...  I think I may be working too hard, down here in my basement every day (my Home Office used to be our Dining Room table, but our Thanksgiving Dinner (for two) took precedent, so I moved to the basement, really not too bad ...).
(2,222 Views)
A green commute!  It looks like Terry beat me to the rest.
"Should be" isn't "Is" -Jay
(2,219 Views)
@Terry_ALE : regarding you hint... is possible join multiple FPGA targets in one Build file? - one click, build and run all.
And more challenging, is possible to build and run PC, RT files, and two FPGA targets by one click?
(1,937 Views)
I don't think it is possible out of the box.
I believe that automation scripts could though.
ALE Consultants
(1,929 Views)
