How to 3D plot the multiple serial port data in real time
I would like to 3D plot the data continiousely reading from serial port. As the 3D plot inputs need to be a matrix, how can I cumulate the multiple channel of serial port data into a 2D matix as the input of the 3D plot?  I put a FOR loop in a the while loop to make the output a matrix, but the VISA close outside of the loop connection is broken, how to solve this issue?  Thanks for your advise.
(3,040 Views)
Would you mind posting your code?
(3,009 Views)
Yep, some images would help us understand the question. If english is not a good langauge then include the question in your native tongue. So lacking details to help I will settle for decorating this thread with images from an app that "resemble that remark".
The follwing image show the config screen for a 3 axis anemometer and uses a vector to show the air speed.
This is the same application in analysis mode and we can see the concentration of methane in a coal mine (data simulated here) and how methane literaly pours out of the coal as it is being mined.
Take care,
Ben
(2,987 Views)
