How program for-loop to calculate RMS with window length of 100 samples and window step of 1 sample
Hi everyone,
I am trying to make a switch from Matlab to Labview from my signal processing needs....Specifically, I need to smooth and quantify a randon, biphasic signal of ~128000 samples in length... In matlab I would calculate the RMS with a window length of 100 samples and window step of 1 sample to smooth.linear evelope the signal; then do my amplitude calculations...
I am having trouble doing this in Labview.. The matlab code I would normally use is:
___________________________________________________________
% Assign RMS variables
x= signal of interest;
window_length= 100;
window_step= 1;
% RMS calculation
EMG= x.^2;
index= 0;
nwindows= floor(nrows - (window_length - window_step)) / window_step;
EMG_rms = zeros(nwindows,ncols); % Preallocation for memory
for j = 1:window_step:length(EMG)-window_length+1;
    index = index+1;
    EMG_rms(index,:) = sqrt(mean(EMG(j:j+window_length-1,:)));
end
I have tried  numerous times using the for-loop, but no luck... Ingore the smilies... They should be a colon (:, to indicate all rows) followed by a )....
Any suggestions??
Message 1 of 21
(8,829 Views)
Can you show us what you have tried so far?
It seems to me that you need a for loop with an Array Subset inside of it.
GCentral
Message 2 of 21
(8,818 Views)
Hi jcannon,
Here is a link with an example on for loops which should get you familiar enough with them to be able to achieve what you need.
https://decibel.ni.com/content/docs/DOC-20828
DylanC
Message 3 of 21
(8,793 Views)
Hi jcannon,
there's a ready-to-use function that should do what you need...
Message 4 of 21
(8,790 Views)
@GerdW wrote:
Hi jcannon,
To be more exact, you need the RMS PtByPt VI.
GCentral
Message 5 of 21
(8,787 Views)
Hi everyone,
Thanks for your feedback with this and the link the the functions...I am ok wth calculating the RMS, my problem is wiring the interation and/or "N" count of the for-loop the get the appropriate sub-array for each signal segment be analysed.
For example, let's say I have a signal that is  5000 samples in length and I want to calculate the RMS for consective windows that are 100 samples long and have the window step of 1 sample each time fr thr total ength of the signal (i.e. smooth it). In this situation the total number of interations for the for-loop runs would be calculated as:
runs= floor(signal_length - (window_length- window_step)) / window_step;
runs= floor(5000-(100-1))/1
runs= 4901.
So, I would the for-loop to run 4901 times (and ingnore the remaining 99 samples at the end of the signal)... In each loop I would calcuate the RMS of the appropriate 100 sample subarray... But how do I wire the interation count and "N" counter to the subarray so that each interations gets the right subarray for each specific interation?...
Jack
Message 6 of 21
(8,763 Views)
Hi Jack,
use the Pt-by-Pt function and you will not need any subarrays...
Message 7 of 21
(8,752 Views)
Of course!
Had a late night...
Any ideas about the wiring?
Jack
Message 8 of 21
(8,743 Views)
Hi Jack,
as PtByPt-RMS only has 2 (useful) inputs for your duty wiring is as easy as this:
But well, one could read the context help to know all this...
Message 9 of 21
(8,733 Views)
Hi GerdW,
I think you might not be correctly understanding my problem regarding the wiring... I am refering to the wiring of the "N" and/or "I" terminal of the for-loop into the coding inside the loop(?) so that the RMS is calculated for the appropriate segment of the signal in each of the 4901 interations... That is, samples 1-100 for the 1st interation, samples 2-101 for the 2nd interaction, etc, etc, through to samples 4802-4901.
I think with the code you have provided, the RMS will only be calculated on the 1st 100 samples of the 5000 sample array...? How to do get the remaining data? I think I will have to use the subarray function with the "N" and/or "I" terminal of the loop wired so that the subarray specs update on each interation to get the new segment of data needed for processing...?
Jack
Message 10 of 21
(8,720 Views)
