How make one graph delayed in XY graph?
Sorry for the confusion. I'm attaching but you cant access the data cause I'm using SQL server to fetch data.
Message 11 of 12
(669 Views)
Accepted by dhanushmh
@cbutcher wrote:
Hey - so I'm not certain that what you explained is still what you want, but the key difference between my earlier snippet and what you've used, as highlighted by altenbach and GerdW, is that in the snippet above, the 'new' data is the only thing being passed to the right hand side of the shift register. The 'old' data is collected from the left hand side shift register icons, and plotted together with the 'new' data.
Unfortunately I don't think I can draw pretty lines around the difference on the forum editor, but hopefully it's clear to you with this little bit more explanation? The key is the branch in the new data wire.
GCentral
Message 12 of 12
(668 Views)
