How make an appear windows for the user ? The user could enter the value he want and after the software will run.
Hi everybody,
I am new in programming with labview.
I am doing an intern ship in a company and I would like to Improve an existing software.
The purpose of the software is to a syringe pump manages to fill a nozzle (connected to
an atomizer) and After spraying has pricise Amount on flies.
So, first, the software Was Divided in to share. I made folders to put in one.
-> Until this, it works
Now I would like to make a program executive for purpose That I-have to, first, find a solution
to control the syringe pump. I explain my self: When I am running the software, the syringe
pump start to run by himself and the User has not the time to enter some values. For safe, I tried
put a button to start the problem Is That goal block the software Spraying Because it s use as a
SubVI. So My idea: I would like to bring-up has windows, Where the user can enter all His gains
push a button and OK to run the software.
If someone HAS an idea Will it really help me !!
Have a good day
Anais
(Here is attached in the front panel)
(2,687 Views)
If you want to give a simple prompt to user you can use Prompt user for input in Dialog and User interface section.
(2,670 Views)
