How long does it typically take to get a solution?
When using the disscusion board, how long does it take to get a solution?  Also, is this service adequate to cover most inquiries?  How does it work when you need support at 2 AM on Saturday?
Message 1 of 9
(4,315 Views)
On the question of how long does it take for an answer just click here and look at the numbers of replies.Smiley Very Happy
Dave
Greets, Dave
Message 2 of 9
(4,301 Views)
I find that the response is rapid, usually within the hour during the day, but can be slower if you post on the weekends or middle of the night (I have never needed to do this thankfully).  Considering the support is free you get a lot more than I would expect.  The speed of the answer usually depends on the quality of the question, so include as much information as possible: version of labview, hardware resources, specific concerns ...
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 9
(4,291 Views)
i think reponse's faster if you include your subVI or at least a screen shot of it too
Message 4 of 9
(4,275 Views)
One important point - this place is run by NI and I believe NI does have an internal policy on answering questions, but most people here are private people who do this on their own. As suggested, if you post an interesting question (or even a simple one, but display the problem accurately and show that you're willing to do your own work), people will usually try to answer it.
Another important thing is to search before you post. This place (as well as the LAVA forums and the info LabVIEW mailing list) has a lot of data already in it and often questions have already been answered numerous times, so really try searching first.
___________________
Try to take over the world!
Message 5 of 9
(4,270 Views)
Well, there are no guarantees. 😄
If you look at the names, there are regular guys and blue guys, the blue guys are NI people. Regular guys such as me are just volunteers trying to help out because it is fun. There are many contributors with 10+ years of LabVIEW programming experience, so the collective knowledge and intelligence of this board is quite high and it is very likely that you'll get an excellent answer pretty fast. Participants are from all over the world, so even at your 2am it will be a more reasonable time somewhere else.
Next to the name are some yellow (or blue)  bars that indicate seniority based on the number of posts, ratings received, etc, so if there are multiple answers pick the one from a more trusted source.
As in real life, the quality of the answer is strongly dependent on the quality of the question. Start with a captivating title related to the core of the question and not something generic such as "please help", labview question", or similar. Explain your problem as detailed as possible, what you are trying to do, what results you expect, what errors you see, etc., not just "it does not work". Many times it is easiest to attach a simplified version of your program. Make sure to put some annotations on the diagram pointing out the problem you see. Put some reasonable default values in the controls so we can run it with real data.
So, just go ahead and ask, it's free! 🙂
Of course there are also premium support options if you want more traditional support with case numbers and live telepone help. Contact your NI rep for details.
Message 6 of 9
(4,266 Views)
Hi, my name is Dan, and I'm addicted to the NI forums. I check several times a day, on weekends and vacations. Does anyone have a cure??
Message 7 of 9
(4,239 Views)
I completely agree with altenbach's point about asking the right question. I'd guess that something like 90% of the time the problem is half-solved when the right question is asked. In the end this is a semi-public board with a lot of volunteers. I say this because you need to consider the type of question you have against the venue where you're asking the question. This is an important point. As a semi-public board there's a number of people here with a lot of LabVIEW experience who are always willing to suggest solutions. However, if your situation is more of a requirement of tech support for a National Instrument product, then this forum isn't really meant to be a replacement for a service contract with NI if your situation really requires that. (I'm sure there's a few blue guys out there that will probably chime in to say this too Smiley Very Happy) Still, the information on this board is free, and people are quite willing to try to help so it should definitely be considered an asset.
unclebump: There is no cure... Simply accept your fate with the knowledge that you are not alone. Smiley Very Happy Hmmm.. Wonder if we need a support group for this forum.
Message 8 of 9
(4,232 Views)
Another thing to remember is that even though it is the WORLD wide web, most of the posts and replies are from the United States.  You will have slower responses on the weekends and at night as well as during US holidays.
Lots of other variables come into play as well:
Quick Helpful Answer:  Plenty of information about problem, sample code showing problem, specific problem with something fairly common, morning in US.
Slow or Non-helpful Answer:   Not much information, no sample code of problem, problem with something rarely used, night in US.
Hope that this helps,
Bob Young
Message 9 of 9
(4,232 Views)
