How insert a Bool type parameter in a dll call node?
Dear all,
I have a function of a .dll of this type:
function(int return, int par1, bool par2)
When I look for a fitting description in the Parameter configuration menu I do not find the corresponding description for the bool variable.
Someone of you can give me a hand?
thanks
(2,727 Views)
You need to know how "bool" is defined in the DLL source code. Typically this is an I32, but it could just as well be a U8. For example, the Windows API defines the BOOL datatype as an "int". But "BOOLEAN" is defined as an unsigned char. Note that "BOOL" and "bool" are not the same thing.
(2,723 Views)
