How get Capital Letters of each items of Ring1 and Ring2
Hello Guys,
I have two Ring(Ring1 and Ring2).
I want to retrieve the uppercase letters for each of Ring1 and Ring2.
And the rest I know how to do.
How can I do it?
Thanks in advance
Message 1 of 8
(3,425 Views)
1. Use the Property node and get the strings of the Ring1/Ring2.
2. In the Event Access the NewVal and use this value to get the index of the selected Item.
3.Use String functions to extract indv letters and based on ASCII Value (65-90) find the capital letters
4.Usetypecast to convert Char to ASCII
Message 2 of 8
(3,416 Views)
Hi @PalanivelThiruvenkadam,
Thanks for your reply.
I didn't quite understand points 2 and 3.
Can you please show me?
Message 3 of 8
(3,392 Views)
  • Convert string to byte array
  • Autoindex on a FOR loop
  • Use a conditional output tunnel that is true if the byte has lexical class=4
  • Convert byte array to string
Message 4 of 8
(3,388 Views)
Accepted by Ngouda
The Ring Property Node could be for either Ring 1 or Ring 2
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 5 of 8
(3,363 Views)
Hi @ @PalanivelThiruvenkadam, @altenbach, @Minions,
Thanks you for your reply.
Thats works now what I want.
Have a good day 🙂
Message 6 of 8
(3,309 Views)
Accepted by Ngouda
I still recommend the lexical class solution. Arguably significantly simpler:
Here's the code for one Ring. It would be easy to expand to two, of course.
(concatenate strings turns the array of strings into a single string).
Message 7 of 8
(3,287 Views)
Hi @altenbach,
Thank you for your reply.
Yes I agree it's  significantly simpler.
I learn a lot in this forum, you're all great 🙂
Message 8 of 8
(3,236 Views)
