How does one run/launch actors in a system under different threads?
As the title suggests, how do you manage what threads actors are launched in?
I have a system I'm troubleshooting now that I beleive is running some things in the UI thread that it should not be- the UI (of windows etc) slows to a crawl, where it takes a second or so even to move a window or open a menu and select an item.
Thanks for any insight.
-pat
(3,153 Views)
I never really considered it, but there's a thread here discussing the issue - https://decibel.ni.com/content/message/83232
In general, the AF group is probably the best place for these.
___________________
Try to take over the world!
(3,128 Views)
tst-
thanks! exactly what I was looking for... my googling skills are apparently weaker than I thought...
(3,123 Views)
Actor-Framework actors don't run in the UI thread, so changing their thread wont solve your problem.  If some of your time-intensive subVIs (or dll calls?) are set to run in the the UI thread, they will still be in the UI thread if their owning actor changes its thread.
(3,083 Views)
