How does implies funciton works?
When I give 110 as x input and 1 as y input I am getting the output as 11111111111111111111111111111001 i.e 11001
But actually negation of 110 is 001; 001+ 1 is 010
Why I am getting the output as 11111111111111111111111111111001
Kind Regards,
Rashme SR
Message 11 of 14
(2,067 Views)
Accepted by Rashme_SR
Your math is wrong.  0b110 inverted is 0b001, then the logical OR of 0b001 and 0b001 is 0b001.  But your input is not 0b110 it is actually 0b00000000000000000000000000000110 because your data type is a I32.  So your output is correct
0b00000000000000000000000000000110 inverted is 0b11111111111111111111111111111001, then logical OR with 0b00000000000000000000000000000001 is 0b11111111111111111111111111111001
Also I suspect the difference between your two outputs is due to how the signed data type is handled, changing all data types to a U32 results in the same output.
Message 12 of 14
(2,061 Views)
OR is NOT an addition.  In digital math, + is often used to denote OR and * is AND.  So 001 + 001 = 001 when dealing with digital math (001 OR 001 = 001).
Message 13 of 14
(2,060 Views)
I understood my mistake..
Thank you so much  Smiley Tongue
Kind Regards,
Rashme SR
Message 14 of 14
(2,042 Views)
