How does fieldpoint write handle network problems?
I have an application that has to control a bank of Field Point relay modules.  It uses the fieldpoint write VI to write data to these modules.   What does the fieldpoint write vi actually do if it can't connect to the module (e.g. network timeout, data error etc)?, and does anyone know how long the timeout is?
Thank you,
Sean
(2,949 Views)
Hi Sean,
I believe the default timeout is 1 sec.  If it does timeout, you should get error 33162.
Chris Bakker
SET Americas
CEO
(2,915 Views)
