How does array obtained in a for loop?
Hi
Firstly thanks for help,
I want to obtain array from the y value calculated in the for loop .at every loop, and in same for loop these different arrays are operated.so with one for loop the calculates are obtained.
(2,817 Views)
If i understand you correctly,
use shift register with "Build Array" function into Loop.
Every iteration add new calculated value to old array (shift register).
(2,817 Views)
