How does SI estimate transfer function produce a transfer function from input output signals??
Can anyone tell me how does the SI Estimate Transfer Function produce a transfer function from input output signals?
Is there any specific algorithms that this vi implements?
If so, will someone enlighten me on  the steps by which this vi produces a transfer function??
setsu
(2,999 Views)
If you look into the documentation (Help)
you find
State-Space Model Definitions (System Identification Toolkit)
Refer to the LabVIEW System Identification Toolkit Algorithm References manual for more information...
The file is found in the LabVIEW<version>/manuals/SIreference.pdf
Greetings from Germany
Henrik
LV since v3.1
(2,968 Views)
Hi Henrik,
Thanks for the reply.
After accessing my manuals directory, I haven't found the SIreference.pdf
If you have the said file or know where to download it, please send it to or teach me.
Best Regards,
setsu
(2,956 Views)
it comes together with the SI vis ... should be on your installer DVD..
Henrik
LV since v3.1
(2,952 Views)
