Create a table or excel with dates everytime a boolean is true
Hello, i have a question about how to do this.
 The basic idea of the program is that when i get a true boolean, i want to register one date and time and a measurement, but only once, until the boolean goes false again. Any idea or tip on how to do it?
Message 1 of 8
(3,203 Views)
Hi edison,
so you want to store a measurement on each rising edge of your boolean?
Then use PtByPt-BooleanCrossing to detect such edges!
Message 2 of 8
(3,198 Views)
And how do i save my measurement, time and date after this?
Message 3 of 8
(3,193 Views)
Hi edison,
you save your data using any kind of file write function!
Which format do you need?
The simple way is to create a CSV file by using some string formatting function…
What have you tried? Where are you stuck?
Message 4 of 8
(3,188 Views)
I tried to use write to measurement file and selected to write it in excel, all of this inside of a case structure.
When the boolean that activated the case structure was true it took around 25000 samples, but i only wanted the rms value of the data i got
Message 5 of 8
(3,161 Views)
Are you using an express VI to make this configuration ?
Message 6 of 8
(3,143 Views)
just wire the desired data to the 1D data terminal of the Write Delimited Spreadsheet function. need some format the data first though, if it is a timestamp & rms either double or string can be used, depending on your preference; with the latter being friendlier to comprehend
CY (expired CLAD)
Message 7 of 8
(3,137 Views)
Its always better o share piece of code/Snippet you developed, based on which we can suggest/ Recommend you the approach to solve the solution, Else it will lead to different kind of questions and followed with your explanation.
So Share the code which you tried.
Message 8 of 8
(3,133 Views)
