How do you write a block parameter value in Fieldbus
I'm trying to write a LabVIEW  interface to communicate with Fieldbus devices.  I have figured out how to navigate down the chain of interfaces to devices to blocks to whatever else is between me and the data I'm trying to get and now that I can read the parameters, I want to be able to write them.  I took my best guess, but when I call the FF write block object (by name), the vi generates some internal error for which there is no description.  I've attached a picture of the code.  Anyone know what I'm missing?
(3,566 Views)
You should use the FF Encode.vi to convert data instead of the String to Byte Array.vi.
Thanks!
(3,530 Views)
Accepted by topic author Jim12345678
The code is fine.  The problem is the MODE_BLK setting has to have a bit toggled for the device to accept changes.
(3,518 Views)
Have to set the mode block to allow writing.
(2,727 Views)
Nested stacked sequence structures?  If a developer wanted to murder you, I'd hand him a stapler.  That would guarantee a painful death.  😉
Bill
CLD
(Mid-Level minion.)
(2,714 Views)
