How do you rotate a Tiff picture without using Vision Development software?
Hi:
Does anybody know how to rotate a TIFF picture in Labview if I don't have the complete Vision Development package?
I do have the limited Vision Acquisition software that allows me to do some basic manipulation but not rotate.
The pic is a binary string.
Message 1 of 9
(4,349 Views)
Hi JPLEng,
how do you get the TIFF picture into LabView? To rotate it you can create an image array like the internal structure of labview, and change the position of the pixel in this way that it represents a rotation of the image.
Mike
Message 2 of 9
(4,333 Views)
Try Image Toolbox at:
http://www.geocities.com/gzou999/imgtool.htm
George Zou
Message 3 of 9
(4,317 Views)
Especially easy are the simple rotations (90, 180, 270 degrees)
But arbitrary rotations are not that hard either:
(you could even use bilinear interpolation for extra fidelity since the pixels don't map 1:1 for arbitrary rotations, ;), see http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=166566#M166566)
Message 4 of 9
(4,294 Views)
altenbach's method looks good for performence.  I give it 5 stars.
Image Toolbox provides high quality image rotation using bicubic interpolation.
George Zou
Message 5 of 9
(4,277 Views)
The code is pretty old and can be simplified. For example, a simple complex multiplication  could be substituted for the rotation code, see:
for an example. Not sure if it would be faster, though. 😉
Message 6 of 9
(4,269 Views)
Thanks for the response:
Can you give more detail?
I'm aware I need to manipulate the bits somehow. Just not sure how.
I figure somebody MUST have already done this.
I'm reading in my TIFF with the Vision IMAQ Read File vi.
Thanks again
Message 7 of 9
(4,238 Views)
I looked at those links. They do not seem to be TIFF friendly.
Have you got them too work with a  TIFF?
Message 8 of 9
(4,237 Views)
LabVIEW can read/write PNG, BMP, and GIF.
Once you have it as 2D array of data, it is really irrelevant what it originally was or as what you'll save it later.
Jim made an example that uses .NET to convert BMP to TIFF, have a look here:
Check the LAVA link for a bug fix. Maybe you can adapt it for your purpose.
Message 9 of 9
(4,225 Views)
