10-20-2005 04:16 PM
10-23-2005 07:51 PM
10-24-2005 04:08 AM
Hi Tammy & Tica T,
As far as I see it - this thread is a very bad version of already existing bad version......
http://forums.ni.com/ni/board/message?board.id=170&message.id=127857
I expected, that an Applications Engineer from NI knows something about a Transistor and how an Output characteristic looks like !! Take a look to a typical Transistor Datasheet ( e.g. n-channel MOSFET) - you will see, that there is no relation of ID vs Time like in your example ( values vs time ) but IDrain vs VDrain at different VGate's ( no relation to Mr. Bill Gates ).
Find attached a vi, that in general does what you need - drawing of curves vs x-axis (XY-graph in use) - in test_sweep.zip. And that you geet an impression, how it might be done ...... dynamic Output characteristic of a Transistor with Standard Equipment of a Lab ( Scope + Generator + Power Supply ) find in addition a Frontpanel - picture. One of the interesting points here is - the self-heating effect; visible on ch3 of scope - 5µs Pulse is already a very long time...... This measurement was done in order to compare with our own Transistors.........
10-21-2007 04:16 PM
10-21-2007 06:45 PM
Muhammed,
I can see you are new to this forum. Avoid loosing your time giving answers to 2-years old threads. Have always a look at the date the question was posted. 😉
Cheers
12-27-2007 01:37 AM
