You can do this using vi server. These functions are located under the "application control" palette. The first thing that you will need to do is open a vi reference. You can use the path of the vi you want to open to obtain this reference. Then you can use a combination or just one property node and invoke node from the same palette. There are also examples of this located in LV find examples. Type in server and you will find example vi's using vi server architechtures. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
