How do you let your app know the LAN's down?
I am developing a distributed control system using FP-1600. I have set up the watchdog timer to put the FP modules into a safe state in the event of the LAN going down. That works fine. My question is - what is the best way to enable my app to discern that the LAN has gone down? I would like to stop it trying to run tests over the LAN if comms have been lost and flag the user that there is a problem.
Niel.
(2,798 Views)
When using the FieldPoint VI's with a FP-1600, you will receive error code 33163, "The connection to the module has been broken" whenever the FP-1600 is offline (due to network failure, wrong IP address or the power to the FP-1600 being removed). You can look at your FP Read.vi, FP Advise.vi or FP Write.vi and check the error cluster for that particular error code.
Aaron
LabVIEW Champion, CLA, CPI
(2,798 Views)
Thanks Aaron. That's just what I needed.
Niel.
(2,798 Views)
