How do you create the waveform data type?
How do you convert analog data read from an external device at regular intervals to the Waveform Data Type?  That is how do you add delta t information to analog data that is sampled at regular intervals.
Howard
(5,932 Views)
Accepted by hrh1818
Build Waveform in the waveform palette.
But if you are using NI devices, the DAQmx driver can be set to output the Waveform datatype.
(5,931 Views)
Thank you for your reply.  I noticed a couple of subtle things I initially missed. Like having to add an element and right clicking on attributes to get at delta t.
Howard
(5,912 Views)
