How do you add 2 physical channels from the same control?
Something like this?
Message 31 of 42
(1,521 Views)
That should do it for you.
Message 32 of 42
(1,517 Views)
Right when I started the VI, a message came up telling me to replace or cancel the file path. I had to click it many times to make the VI run all the way through.
Message 33 of 42
(1,515 Views)
Did you put an actual file path in the control before you ran your VI, or did you leave it blank?
Message 34 of 42
(1,500 Views)
I added a file path, but I wasn't sure what extension to include. I put .txt
Message 35 of 42
(1,487 Views)
The extension doesn't really matter.  What does matter if you actually used a valid path.
Message 36 of 42
(1,466 Views)
In that case, I definitely used a correct file path
Message 37 of 42
(1,454 Views)
I made some alterations, but still, whenever I click the run button, a message comes up asking me if I want to replace my file or cancel. I have to click this error upwards of a 100-200 times before my short VI ends.
Message 38 of 42
(1,437 Views)
You need to wire the append to file? input of the Export Waveforms ....vi. On the first iteration it should have the default value so you create a new file (if the file does not already exist) and it should have the opposite value on all subsequent iterations so that it appends to the existing file.  Read the Detailed Help for more information.
Lynn
Message 39 of 42
(1,428 Views)
Would a case structure be the best way to go about this?
Message 40 of 42
(1,419 Views)
