‎02-23-2012 08:22 AM
I read something about setting up a DSN or UDL. How is that done?
I do have the LabVIEW Database Connectivity Toolkit and LabVIEW development 2011.
Also, i copied a DBF file to my desktop for testing. Would that work?
Thank you.
‎02-23-2012 01:25 PM
The Database Connectivity Toolkit ships with examples to do exactly that. Have you looked at them?
In terms of setting up a DSN, that is done with the Data Sources applet. This is usually available in the Administrative Tools folder.
‎02-24-2012 02:24 AM
I usually use a .UDL. It can be set up via the applet, or simply create an empty file with the .udl extension and double click it to change the parameters.
/Y
