How do i locate this symbol
What symbol is this and where can i find it?
Thank you.
(2,878 Views)
Accepted by topic author Carefree
Hai,
Its "Bundle" function and can be located in the function pallete in the following path : programming>>cluster, class & variant.  You can also use search to locate this function in the function pallete.
It is used to form a cluster by assembling individual elements.
revert back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,863 Views)
Ah great, found it!
Thanks alot...
(2,852 Views)
