How do i get the x and y values when user double clicks the graph plot
Hi All...
I would like to know is there any solution for my problem.
I have an xy graph wth data points.I need to read the values of x and y coordinates when user double clicks on a data point on the plot.
Is there any way to achieve that?
Message 1 of 9
(3,431 Views)
See the attached VI.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 9
(3,424 Views)
Pls send me again in 8.0
Am using lv 8.0
Thank u
Message 3 of 9
(3,422 Views)
find the same vi in 8.0
Balaji
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 4 of 9
(3,411 Views)
Hi..
Thank you for the help.Actually i need to know the coordinates only when the user double clicks on the datapoints on the plot.
Any way for that?
Thank u
Message 5 of 9
(3,398 Views)
Attach your VI with sample data saved as default values. We can help you further...
Message 6 of 9
(3,394 Views)
user_1 wrote:
Hi..
I think this will be pretty much difficult to do directly using methods or properties.
But you can always look for the value of the plot at the double-clicked position & then take the X & Y coordinates of that point.
Message 7 of 9
(3,381 Views)
 Ya its  having complications to show only when the user double clicks on the datapoints on the plot(as already partha told). See this attachment it may help you, it gives the actual data points value.
It is required to show only when the user double clicks on the datapoints then get the x,y coordinates and search in your data array with some offset because user will not accurately click the point. If u found the x,y values in your data points then display the values.
Balaji(CLAD)
Balaji PK (CLA)
Message 8 of 9
(3,365 Views)
Balaji's VI in LV 8.0 format.
Message 9 of 9
(3,361 Views)
