How do i count different characters from a text.
Use typecast on the U8 number to get the character as a string.
Message 11 of 30
(3,135 Views)
I would use To Upper to make all of the letters an uppercase and then subtract 64 from the U8 equivalent (capital A = 65 in the ASCII table).  That will give you the index of the element that needs incremented.
Message 12 of 30
(3,134 Views)
@Jenson94 wrote:
Oke thanks, now i got everyting in the different classes but how do i cast it back an select those from the right array?
Here's one possibility. To put things in a graph should be trivial (except for labeling the x axis markers). 😄
Message 13 of 30
(3,109 Views)
You can make it a little simpler by removing the case structure.  If you try to access/set an idex outside of the array, the array doesn't change.
Spoiler
It is very rare that anybody can make Christian's code any simpler.  I have to jump on this whenver I can.
Message 14 of 30
(3,090 Views)
Another approach is to use variant attributes.
Ben64
Message 15 of 30
(3,080 Views)
I have to say i'm inpressed with your nowhow on labview! But how do convert a string to a graph? Do i first have to make an array of the string or something like that?
I'm learning so much from this, thank you guys!
Message 16 of 30
(3,047 Views)
The array coming our of the first loop is all you need to send to a waveform graph. Select a graph style that looks like a histogram. It will look like the picture attached to your first post.
The x-axis is as follows 0=a, 1=b, 25=z etc. as I said, to get the actual characters on there requires a bit more work. 😉 To have the axis go from 1..26 instead, change x0 to 1 in the graph properties. (See attached quick example)
Message 17 of 30
(3,045 Views)
Thanks guys, I really appreciate you are helping me!
Can somebody explain the block diagram from the last post? I'm understanding it for about 85% but stil not 100% shure on how it works?
Message 18 of 30
(3,012 Views)
Which 15% of the diagram puzzles you??
Message 19 of 30
(3,004 Views)
The part of the in place element structure!
Message 20 of 30
(2,989 Views)
