11-27-2007 10:28 PM
11-27-2007 11:20 PM
11-28-2007 09:12 AM
11-28-2007 02:24 PM
11-29-2007 10:47 AM
12-08-2007 01:45 PM - edited 12-08-2007 01:52 PM
Yeahh!! moreless what I was trying to do, I apreciate your effort, I apologize for my delayed answer, but I don't understand what you did after the 180 divide, I think that helps me but I wonder if you can explain exactly what you did please
ZZ
By the way I'm Mexican too.
12-10-2007 09:48 AM
12-11-2007 07:30 PM
12-12-2007 10:16 AM
ZZ,
If you open the Context Help and point the XY Graph on the block diagram, you will see that the way it takes the input is a cluster made up of two elements, each element is a numeric array, one for X and one for Y. Since the cluster expects arrays as inputs, we cannot wire a scalar dbl value for x and another for y if we only want to plot one point. However, we can 'fool' the cluster using a Build Array of one element.
I am not sure if I understood the last question, but there is a way to customize indicators and controls and you can modify them up to certain extent. Right click on the front panel control and select Advanced - Custimize. You can modify the graph (colors, size, location of elements, etc.) and then save it as a different control (.ctl file).
I hope this helps. Have a good day.
