How do I synchronize the 2 analog outputs?
I am using labview 7.1 with an 6221 M serie device. I would like to generate 2 output signals :
1) A square signal ( changing value every 60 secs for instance )
2) A step signal that has about 8 different constant values that change every 4 min for example ( 4 minutes at 1.5 V, 4 minutes at 3V,4 minutes at 4.5 V ... and so on )
I would like to synchronize these two signals so that they start at the same time. Could anybody give me a hint on how to do this?
Up to now I have used the continous square generator example for the first signal. However, I now have to synchronize it so that it starts with the second signal. If by the way anybody already has an example that I could use to make up that second signal, it would be a great help...
Thanks for any kind of help,
David
(2,867 Views)
Try this one. You may have to modify the DAQ Assistant for your card.
Randall Pursley
(2,860 Views)
Hello Randall,
Your VI is EXACTLY what I was looking for ! I have inserted a read to spreadsheet to output the values of the step signal and it works fine.
Thanks a lot for your help and for answering so quickly,
Kind regards,
David
(2,846 Views)
