How do I sum all the elements of a 1-D array?
I'm using Labview version 5.1.
(8,432 Views)
Hello Emma,
even in LV5.1 you should find a function called "Sum up Array elements", probably in the math palette.
If you want to do some special math, you can use a simple For-loop and sum up the elements by yourself.
(8,432 Views)
