How do I set up LabVIEW V6.1 to output analogue signals using a LabJack U12 interface card?
Hi there,
I have a LabJack U12 interface card that has two analogue outputs, AO0 and AO1. What I would like to be able to do is set up LabVIEW V6.1 to eventually control the dimming of some external lights, from say a simple control on LabVIEW's front panel.
I will have some external circuitry connected to the interface card to perform the dimming of the lights, so all I will require is a variable voltage on the output of the card. I think the specification of the card is 0 to +5 volts for the two analogue outputs. I have tried looking on the website for LabJack (www.labjack.com) for any ideas, but with no success! Please find my LabVIEW file as an attachment.
I would be very grateful for any help on this matter,
Neil Sampson.
(2,919 Views)
On the labjack downloads page:
http://www.labjack.com/downloads.html
Pick "Labview5 VIs" download. In the zip file is ljacku50.llb, which contains EAnalogout.vi for outputting an analog signal.
2006 Ultimate LabVIEW G-eek.
(2,919 Views)
Hi there,
Thanks for the link...I have managed to implement the vi into my application and everything seems to work!
Cheers,
Neil Sampson
(2,919 Views)
