How do I send SQL statement to SQL Server and return data without using Database Connectivity Toolkit?
Hi,  I've been trying to figure out how to pull data out of my SQL Server databases and from reading some posts and doing some tests with examples, I can kind of get data connecting into my SQL server, but so far nothing that helps.  Is it possible to actually get data out of a SQL Server database without using the Database COnnectivity Toolkit?  and if so, how?  are there whitepapers and/or examples of this?  So far, I cannot find anything that works.  thanks.
(3,551 Views)
I haven't ever done it before in LabVIEW and don't have the time to do much of the research right now.
That having been said, you will want to look for either a .NET library or an ActiveX control. Aside from the toolkit, you aren't going to find a native solution to LabVIEW - which means using other libraries. A quick google search returns this:
http://msdn.microsoft.com/en-us/library/ms810810.aspx
which may help.
(3,546 Views)
I found a old post over at the other side, that talks about connection to SQL databases:
http://lavag.org/topic/7240-best-way-to-interface-labview-to-sql-server/
One tool I have seen is LabSQL, try to search for that.
(3,540 Views)
Accepted by Jesse_Larsen
Jesse - What is your reason for not using the Database Connectivity Toolkit? That is by far the easiest way to grab data.
(3,517 Views)
