How do I search for a subarray of bitstreams within an array of bistreams?
I have an array of bistreams padded with random number of 0s at the beginning and end of the array.
array 1 = 0 0 0 0 ... 1 1 1 1 0 0 0 0 ..... 0 0 0 0 0
I need to remove these 0s at the beginning and end of the bitstreams. Since I do not know the number of 0s padded at the beginning and end of the array, I cannot directly use array subset.
But, I know that 11110000 is the start of the information I need within array1. So my array2 = 1 1 1 1 0 0 0 0. Now I need to search for array2 within array1 and get the starting point index. How do I search for a subarray bitstream within an array of bitstream?
(2,302 Views)
Hi wannabe,
again you forgot to define the datatype of your "bitstreams"…
repeat
   Search for "1"
   Check if you found the "1111.0000" start marker
until "marker found"
(2,270 Views)
Hi GerdW,
sorry. So the each bit in the bitstream is U8 data type. So each bit is a U8.
Warm Regards
(2,264 Views)
Accepted by labview_wannabe
Hi wannabe,
ok, this simplifies the implementation.
See my pseudocode above, you need
  • (while) loop
  • shift register for the current search position
  • Search1DArray
  • ArraySubset with a comparison afterwards…
(2,256 Views)
@GerdW wrote:
Hi wannabe,
  • (while) loop
  • Search1DArray
Thanks GerdW. I used your method to search for 1 but I didn't use while loop. Hope this helps for someone else.
(2,219 Views)
Hi wannabe,
  • Please post real code next time instead of just an image of code…
  • Cleanup the code before posting!
  • You don't need to wire the length input of ArraySubset to get the "rest" of the array, and so you don't need all those calculations…
  • I prefer to have terminals not in "Show as Icon" view, but definitely hate to have a mixed set of terminals in small and icon view…
(2,205 Views)
