How do I reinitialize a multicolumn listbox to default?
How do I reinitialize a multicolumn listbox to default? For example, say I want a blank listbox any time the VI is started. While the VI is running, property nodes are used to write specific values to the listbox.
Using the invoke node with a method of Reint to Dflt does not work.
(3,286 Views)
You use the same property node that you're using to write specific values (Item Names). The only difference is that you wire an empty 2D array of strings.
(3,286 Views)
