Cstring pointer dll
This is a really simple question.
I make my own dll and I would like to pass a Cstring from Labview to this dll. The dll is in C++. When I pass the string in the Call library finction node, I can pass a Cstring pointer.
How my prototype in C++ should be? void function(string *thestring); or void function(string thestring);? (because it's a Cstring POINTER)
thanks
(4,259 Views)
hi poly,
just build up the parameterlist of an empty CallLibrary-Node and right-click "Create C-File" on the node (you don't need to specify a dll when building the parameterlist). LV then creates a C-Code stub for you.
greetings
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,259 Views)
I'm not really sure I understand what you mean. I will try it.
However, the dll is already done and I can change it so I think I would be less complicated if I just change the input parameter in my prototype from "string thestring" to "string *thestring".
I'm just a little mixed up in the definition of a "Cstring pointer".
Thx
(4,259 Views)
You can try doing void function(std::string thestring), that might work because of copy constructor on string.
However i usually have void function(TCHAR* thestring) and that does work.
A Rafiq
(4,259 Views)
In terms of LabVIEW a C string pointer is just an array of characters terminated by a NULL character. When LabVIEW calls the DLL, it will pass a pointer to an array of characters where a 0 defined the end of the string.
The function prototype can be something like
void MyFunction(char *myString);
I know MFC offers the CString class to make string management easier. You can go back an forward between a CString tyoe and a char[]. You can assign a char[] to a CString with the "=" operator and uses the LPCTSTR operator to convert a CString to char[].
I hope this helps
Juan Carlos
N.I.
(4,259 Views)
